I drove my truck today!!! FINALLY!!!!! Do you believe me?
Its true.. Im excited.. Still have lots to do in order to get it on the trails. ( re-route exhaust, lower the front , front driveshaft, gear and locker install, other small things) But i can say now that its semi-driveable...
I need to go get the exhaust re routed because it hits the shock. i just turned it so that it wouldnt hit....
The front is way too high right now. The plan is to weld on some tabs higher up so that it will lower the front to match the rear. I like how the rear sits and would rather lower the front than raise the rear..
Other stuff id like to get done soon. Soft top installation, cage, fender tubing, and other small stuff..
So back to the driving part.. i found an annoying leak in the brake system and fixed it last night. I bled the power steering again this morning, tightened up the steering and drove it around the block.. the flat spots in the tires were awesome, klop klop klop klop, ..
it was fun.. it last moved under its own power last Thanksgiving weekend..
proof..
proof..
