1 - 4 of 4 Posts
I recently had to replace the base of the pedal of my bronco 91 synchronously , after replacement made ​​me not fall speeds and also turns me on when operating the pedal crochet, I do ?:whiteflag
Retired
Welcome to the site. I would check the plug at the steering column. If you replaced the brake pedal base you probably have a loose connection at the wiring causing it to turn on and off.
1 - 4 of 4 Posts
