yo,
Just in case;
DTC P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control "...Indicates the ECT or CHT sensor has not achieved the required temperature level to enter closed loop operating conditions within a specified amount of time after starting engine. Insufficient warm up time; Insufficient warm up time Low engine coolant level Leaking or stuck open thermostat Malfunctioning ECT sensor..."
miesk5 Note; Remember to have engine @ Normal Operating Temperature before doing the KOER portion
DTC P0300, P0302, P030X, Random; Multiple Cylinder Misfire Detected; Symptoms, Causes & Possible Solutions
Source: by miesk5 at
http://fullsizebronco.com/forum/showthread.php?t=168760
A P0300 diagnostic code indicates a random or multiple misfire. If the last digit is a number other than zero, it corresponds to the cylinder number that is misfiring. A P0302 code, for example, would tell you cylinder number two is misfiring. Unfortunately, a P0300 doesn't tell you specifically which cylinder(s) is/are mis-firing, nor why.
Symptoms may include:
the engine may be harder to start
the engine may stumble / stumble, and/or hesitate
other symptoms may also be present
Causes; A code P0300 may mean that one or more of the following has happened:
Faulty spark plugs or wires check each wire for connection integrity first. Ensure that routing is ok;
Look at that VECI Label on top of radiator; look at the spk plug wire routing diagram carefully.
Spark Plug Wire Routing & Firing Order TSB 94-04-10 for 87-93 5.0 & 94-96 5.0 & all 5.8 - engine miss, spark knock, buck/jerk, surge and other driveability concerns
Source: by Ford via Steve83
Test coil before pulling plugs to inspect again and re-gapping to save your time & $
http://www.msdignition.com/page.aspx?id=3206
Re-gap Plugs
Faulty coil
Faulty oxygen sensor(s)
Faulty fuel injector(s)
Burned exhaust valve
Faulty catalytic converter(s)
Stuck/blocked EGR valve / passages
Faulty camshaft position sensor
Defective computer (not likely)
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
Random misfires that jump around from one cylinder to another (read: P030x codes) also will set a P0300 code. The underlying cause is often a lean fuel condition, which may be due to a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
P1131 - Lack of HO2S-11 Switch, Sensor Indicates Lean A HEGO sensor indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time
check for vacuum leaks
