1 - 14 of 14 Posts
Teddy Bear
well ive ran the gammit on everything but my truck wont start turns over just fine, but will not kick over, i pulled thee eec out about a month ago i was redoing the floor pan, and part of the fire wall, and i pulled the eec because it was in the way, well i may have dropped it, could it be bad because i dropped it? if not, would it still crank over if the eec was screwed up, i think water got into the cab and short circuited it, if you all have any suggestions, or an 86 eec i can borrow let me know
green ones make me horny
So you dont know if you dropped it? I think you can get it tested at the stealership, im not sure. Is your truck Fuel injected? If not I dont think the EEC will have anything to do with it starting but im not too sure on that one.
check your alt, battery, solenoids, starter, coil, dizzy everything
it would be easier to check spark with the sun going down lol.
just grab on to the end of one of the wires and have a buddy crank it over:shocked you'll know if it has spark or not :rofl:
Teddy Bear
Discussion Starter #12
ok i just pulled her into the garage and let er charge and i was cranking he had she kicked and just went back to cranking, any idea, this may end up in the emergency help area but it didnt start that way
Satyr of the Midwest
As already mentioned,
broncos&bombs said:
are you sure its getting fuel and spark?
1 - 14 of 14 Posts
