OK all. So I had to step away for a bit and regroup.
I actually called every mechanic within a 100 mile range and nobody works on older vehicles anymore.
Its only an 86 sheesh.,
Anyway, I have decided to try to fix it again myself.
At idle she seems to be running very well.
Put into gear and immediately dies unless I tap on the accelerator.
I tried a trans stall test. Foot on brake and try to rev it up in F and R and immediately dies. Not even remotely a chance of revving up.
I also then climbed under the truck. Pulled off the vacuum line on the vacuum modulator and out came some transmission fluid.
Not a lot, but is there supposed to be any?
Any thoughts on this matter?
What else should I test/check?
I did read that some have had issues with the filter coming loose and getting air is system.
Also loose or bare wires causing a short, but I didn't see any.
BTW, 1986 351W with auto trans. Brand new rebuilt carb. New Cats, all new ignition parts except distributor.
