We received our new Motorcraft IAC and installed it. We also installed the IAC Spacer Kit. We repaired the damaged IAC mounting threads with 6mm x 9mm Time Serts. All Throttlebody, IAC, and upper intake gaskets were replaced.
The idle with IAC installed is 1200 RPM. The instructions that came with the IAC Spacer (I.S. 6273) mention adjusting one or both air Trim Screws. CCW to decrease RPM. We have turned both trim screws CW 2 turns with no change in RPM. I am getting worried that they will soon drop inside the IAC and find their way into the engine.
The throttlebody does have holes in the the throttle plates. I have read that the original throttlebody did not have holes and that holes were later added to prevent vapor lock.
I have also found reference to a kit, Ford Service Kit (FOPZ-9F652-A) to block the holes on the newer throttlebody. I have found limited info and no such part to date, but I am still looking.
I am going to try putting a square of Gorilla tape over the throttleplate holes to see what happens. I will be careful not to open the plates to prevent sucking the tape into the engine.
The TPS is a new motorcraft. It has a range of 500 - 3.75k ohms.
Any help would be appreciated. Rain is predicted for the next 5 days and we are working outside in the driveway.
