FYI:
You don't need to go to the JY for that "ogtagonal tree part, just disconnect
and take out then all you have to do is drill out the remaining cooling tube
piece and tap in 3/8" threads then go to Lowe's etc. and find a {5/8"} brass
{hose barb} with 3/8" {pipe} threads AND in the future you now have the
ability to "unscrew" the cooling tube from the "octagonal tree" which then
unscrews from the lower intake manifold to replace the ECT sensor if need
be WITHOUT having to turn the distributor out of the way. Yeah!
I did mine that way a number of years ago with no leaking issues since...
Cool idea thanks, JK, I'm gonna do that to all of 'em I mess with from now
on.
The threaded nut (1/2" pipe threads) on the bottom is "supposed to" turn
and leave the side-pipe stationary but in my experience that sucker doesn't
turn easy enough. Ford had a good idea but in practice it didn't work out
as planned?
Alvin in AZ
ps- An idle thought... since I don't have coolant running through the heater
core or the throttle body neither one... was to tap a new 3/8" pipe hole for
the sensor and get a 90* elbow brass hose barb with 1/2" pipe thread and
getting rid of the tree all the way. Hadn't looked into it at all, just thinking! :/
pps- Just use the original hole in the intake manifold with a special Tee...
www.McMaster-Carr.com
9171K34
or
4757T54
plus
4429K413 for the sensor
and
5346K66 for the heater hose (comes in a 5 pack)
