1 - 3 of 3 Posts
Yeeeeehaw Y'all!
Has anyone installed an idle adjustment spacer kit for the EFI?
Anyone have any opinion(s) about if this is really a helpful addition?
I'm not having any engine issues, but I wouldn't mind having an easy way to adjust idle speed in the event of.......... :shrug
Jeff
Just crank out the stop screw on the throttle plates until you get the idle you want. Unplugging the IAC helps adjust the idle... the ECM is going to want to see it near stock, tho.... all you're really doing is adjusting it so the IAC only opens for fast idle.
OUT OF BUSINESS / M.I.A.
:stupid
It would be easier to adjust the idle with the stop screw, then adjust the TPS and re-set the computer.
1 - 3 of 3 Posts
