I've been flamed before regarding this and I understand the "racing application" may not apply with respect to .55v-.75 volt setting for a stock engine though many here have stoker racing style engines where it might apply ? BUT the .93-.97 volt setting has been "touted" by every top guru on this site for quite some time so I don't see an issue with that.
With regards to the throttle body idle stop screw and IAC, that procedure was posted when I first joined FSB by a member who said he was Certified Ford Tech and that's the way they did it at the Ford Dealership but that it was for "baseline idle". As I've always stated if you decide to turn the scew make sure you either count the protrouding screw threads on either side of the TB block or mark it with chaulk for reference in order to put it back the way it was AND I have to believe the screw can be zeroed out to factory spec's, more then likely they way they designed it IMO.
It doesn't take a genius to figure out that Ford Motor Co. wouldn't have wasted money for tool and dye on a small intricate spring loaded screw and threading for tens of thousands of vehicles if it weren't supposed to be "functional", why not just mgf. a "fixed length idle stop STUD" instead and eliminate any confusion.
As for disconnecting the battery to default to OEM factory settings, what happens when you swap in a new battery and the BKO has been disconnected for more then a half hour or so.......?
It's probably better to use a Ford Code Reader to clear codes but I've done all of them a number of times and I've never had any issues or problems so I'll stack my engines performance against anyone's, maybe it's just fear of the unkown....lol lol
Do I get it right all the time, no but neither does anyone else here so perhaps this will make everyone more comfortable: :doh0715:
http://www.fullsizebronco.com/forum/showthread.php?t=203080
Good Luck ~ :thumbup
