I agree here X infinity....lol lol
A. FIRST always "pull codes" to see what elec/electronic faults are indicated for initial diagnosis and FYI, there are no fault codes for FPR = fuel pressure regulator it's a vaccum issue and requires using a fuel pressure gauge testing for psi.
B. Check/test voltage settting for TPS....originally thought to be .93v -.97 volts but rather now .55v -.75 volts.
Posted by FSB member Jermil01:
Wanted to update this thread based on some TPS adjustment information I got from one of my tuning sites. This goes against the conventional wisdom of setting the TPS closer to .95 range. Thoughts??
Regarding any ECU controlled function (and idling conditions in particular), before any strategy based adjustment can be made by a computer controlled system, it must first run somewhat normally in a default and OL mode. To do this with a FORD you must first follow a few rules.
You must keep the TPS input above the deadband area and below the "tip in" area. On a FORD this equates to below approximately 0.9V and above 0.45. Anything above 0.90V the ECU thinks the throttle is starting to open. This brings into affect possible dashpot and fuel cut strategies which can turn one grey real fast. Below approx 0.40-0.45V the system suspects an incorrect input and substitutes a default figure. So first off, the TPS should be set to around 0.55-0.75V.
Most TPS sold today are the "plug & play" style with no adustment using a multimeter but there is a Ford Racing Performance Parts (Techline (800) FORD788) ~ idle setting instruction sheet steps 1-9 for IAC and suggestion to drill out the TPS = throttle position sensor mounting screw holes in order to adjust voltage setting which controls throttle body "blade angle air induction".
C. Clean, replace gasket and check/adjust IAC according to ^ the procedure above.
D. Check and replace air filters and PCV filters if need so the engine can breath properly.
E. Get a Haynes Repair Manual rather then use the Chilton, most here say it doesn't "read" as well compared to the Haynes, Red version (older) Green version (newer)
Good Luck ~ :thumbup
