Norseman8305:
Any of these could contribute to the problem but first you need to "pull codes" from the PCM - power control module which is located under the dash right of the steering column, the connectors for pulling codes is located under the hood right side near the battery. So find out what the BKO is doing, then you do KOEO - key on engine off and, KOER - key on engine running the PCM performs the diagnostics then spits out a code. Codes can be copied FREE from
www.fordfuelinjeciton.com this site is owned by Fireguy50 who is a FSB member.
There are numerous threads regarding "How to Pull Codes" SO SEARCH . :doh0715:
The module is called a TFI -Thick Film Integrated Module which is attached to the diisy outside, failure is quite common when cold, hot then cold etc. You can have it tested for free at an Autozone type place or get a reman dissy complete with both TFI & PIP sensors from Napa for about $130. out the door. :chili:
PIP - profile ignition pickup sensor (Hall Affect Sensor) inside on the end of the dissy shaft which has to pulled out to replace that sensor PITA. :banghead
TPS, this just sets the blade angle of the TB
IAC - you can clean it with TB cleaner replace the gasket and if necessary set the idle using the your Tach & TB idle stop screw for correect idle according to Haynes. :duh
Varying voltage can also play a part in all of these so you'll need a multmeter.
Changing valve cover gaskets won't cause you any of the problems unless you inadvertantly did some damage to your harness or wires leading to any of the afore mentioned.:twak
Welcome to BRONCOLAND the home of continous repair work in progress. lol lol
Good Luck ~ :thumbup
