Question in respect to the wiring involved in starting ab 85 Bronco. More specifically, when I bought my Bronco, the previous owner installed a push button start right next to the cup holder. At first, I was a fan of this but now not so much.
The reasons as to why I don't like this push button system is that it makes the vehicle harder to start. more specifically, pushing the start button does not direct all of the power to spark and start alone. this being the case, i did realize that when pushing the start button, i could also turn the key in the ignition cylinder to the crank position to direct all power to the starting circuit. this worked great for a while until the ignition switch downstream of the steering column fell apart as they usually do in 80's Ford trucks.
When the ignition switch was replaced, I lost the ability to direct all of the power to the coil and starter when i was twisting the key and pushing the start button.
to sum it up, i am looking to revert the starting circuit back to factory for easier starting.
side note: twisting the key to the engine crank position in the ignition cylinder alone does not engage the starter solenoid.
Thank you in advance for the help!
