1 - 16 of 16 Posts
Alright guys, ive been out of the bronco game for a while, havent had time to work on my baby due to being busy with graduation. :duh
As stated above, im replacing the ignition lock cylinder, or tumbler. I searched for tips, and came up with nothing. Naturally, not wanting to screw anything up i thought id ask if anyone that has done this before can point me in the right direction, as my bko is at my dads, and ill need to bring all needed tools with me. Btw, nice to see the site has grown a bit since last fall.:thumbup
Currently FSB divorced
Easy as pie- First turn the key to start but don't crank it over next there is a small hole on the bottom that has a pin you need to push it with a pick or small screw driver- at the same time pull on the cylinder and poof! it"s out. Install in reverse order and when you turn key to off after the cylinder is in the hole that pin will lock it and your done- bob
That's why were here. It's also how i learned how to do EVERYTHING to my vehicle! :rockon
I see Broncos
Not sure if that scares me or not...
But yea it's real easy I have done it a few times on fords.
I don't think you can because that little button won't push up until it is in the start position. Maybe a big F'n slide hammer worked great when i was young and stupid!
Sorry to hijack but my on my ignition it binds up and the metal rind around the outside that is used to help you turn the key will turn some without the kep being in it. Does this mean i need a new ignnition lock cylinder?
Discussion Starter · #9 ·
It turns out, I go to the dealership, buy the cylinder for $32 and change. Go to install, and (duh) dont have my key! So what do i do? I put one of the keys that came with the cylinder into the original keyhole....and start the bronco! Hahah it was hilarious, besides the fact I spent $32 on a set of keys.:twak
I would feel bad about copying the keys and returning the cylinder, even though I doubt the dealership would let me. I'll just keep it because i know if I return it, I'll need one soon after with my luck.:toothless
Steve83 said:
Slicker
The pin can be drilled out, if you're VERY patient.
Ya -but when your steal....I meant borrowing a ride- time is of essense. This was a loooooooong time ago!
It's BTW Not AKA!
My outer ring will also move and bind alot sometimes. I have actualy started the truck once without the key. Time for a new cylinder?
Yup, I'm fullsize....
Thanks Slickerthanyou and Steve83 :rockon
I just replaced my ignition cylinder. The "dog ears" surrounding the key broke and were spinning. It took like 3 minutes to figure out how to pull the ignition cylinder thanks to this thread and the pictures on Steve83's supermotors site.
The local stealership wanted $75 for the ignition cylinder and had to order it. I politely told them where they could send that order and walked out the door. I found one a AZ for $18. Don't know how long the AZ one will last though. Now to find a locksmith to rekey the new one to match my door keys.
1 - 16 of 16 Posts
