This is weird, to me at least.
My experience with ignition interlock switches is that if you're not in park, neutral, or the switch is misalingned, no crank.
My '89, maybe a couple of times a year, will crank strong, but won't fire. But I found out that if I pull the shift lever up hard and back, it'll fire. That sounds like the interlock switch, but it doesn't either. I thought the interlock switch only intercepted the line to the starter relay. WTF is going on here?
