1 - 3 of 3 Posts
Ok this one is pretty far out there. I just finished putting my bronco back together after getting the frame powder coated. I started it and drove it around just fine then it would die when put in park. Then i went to restart it and it wouldn't turn over, no clicking or anything. So i cleaned my ground, had the battery and the starter tested, both we're good, changed the starter solenoid and none of that worked. Then i changed my neutral safety switch and it worked. Went and drove it around some more put it in park and it stayed running. Now I'm excited that i fixed it. Well.... Got back home and put it in park and it dies so i start looking up reasons for that and went to turn it on again and nothing happened again!!!! I'm at a loss. I need help bad
Is it safe to assume you just finished a frame off restoration. since you mention powder coating the frame?
Given what you mention doing, ground, starter, netural safety - I would look at the ignition switch.
1 - 3 of 3 Posts
