You guys were a HUGE help last time, and now I've run into another electrical brick wall. About a month ago, i had to leave my bko outside overnight in the -10F cold. When I went to start it, nothing happened, not even a drain on the battery. So I popped the hood, looking for answers and in the end, stuck the key in the run position, stuck a screwdriver up to the posts on the starter relay and vroom up it started. After that, it was about 50/50 whether it would start with the key, or I'd have to pop the hood and start it. Now, it NEVER starts with the key. So I put in a new relay, no change. So I started metering. In the start position, I get about 8 volts through the small clip to the small terminal on the relay. Is this enough to trigger the solenoid? Or do I need to chase more wires down?
After it's started everything is great, charges fine, runs fine, shuts down fine.
Ideas?
Ideas?
