I have a question about the timing pointer on my 351 HO (1985) - What part of it do I read from? What is a good baseline for timing?
Sackman has you straight on the marks and which pointer to use.
Assuming you are using the stock cam and ignition system, 10-12* BTDC works good on most Ford V8's.
From the FWIW Dept:
If the engine in your photo is the one in question, right now while the heads are off is a real-good time to possatively locate TDC on the #1 piston and compare that to where the marks on your balancer says it is. Don't be surprized if you discover them to be off a couple of degrees.....or maybe by a bunch if the balance ring has slipped.
The object of this exersize is two fold;
1)....Establishing a correct relationship between where the crank is and where the pointer says it is. Otherwise, you're only guessing at where you're setting your base timing.....timing light or no.
2).....You'll find out perty-quick whether or not your balancer has slipped. If it's off by more than a degree or so and/or if the rubber is cracked, oil-soaked or hanging out more in one place than another, don't bother remarking it....just buy a new one. Aint no easier time to change it than right now while the motor is sitting on a stand.
Hope this helps.
DGW
first off you need to buy a jeep!!! then take the motor out of it and put in a chevy 305... Then you will be close to good.
:rofl:
listen to sackman, he will show you the way:thumbup
Nice on having the engine out on a stand, build that puppy!!! Built right you'll get better mileage (when you aren't hotrodding it) and more power.
Thanks for the information guys!
This is an old picture, the engine is built up now. I am running lightning heads, a weiand stealth intake, mild street cam, etc in a 1968 fairlane. I was trying to time the engine yesterday and couldn't remember what mark to use.
