Hello all,
It looks my father broke his bronco again. This is what happened as he tells it. He backed the truck up to the barn, roled the back window down, shut the truck off, put something in the back, used the dash switch to role the window up but the switch didnt work. Used the key and it went up fine, put the key in the ignition to start the truck up, but the truck didnt turn over, and the window wont go up or down with the switch or the key.
Im guessing the back window is unrelated to the starting problem but I could be wrong
I went out and looked at it, and it seems like something in the steering column broke. The key turns to the "run" position and the fuel pump comes on, but it doesnt have any "resistance" like it does when the starter engages. The key just stops turning. I tried putting the truck in Neutral. Still no luck and now I cant get it back into park.
I did some searching and read about somethng called the "ignition actuator". Would that most likely be whats broken in this case? Or is it something else?
Im going to need to get it fixed sometime this week, but I know dick about mechanics, and Im hoping someone here would be willing to hold my hand while I do this.
Thanks, and sorry for the long post.
