On Friday my Ignition started binding up. I couldn't turn it backwards to accessories at all and it would get stuck in the start position, it took all my strength to disengage the starter.
So, I figure it's the ignition actuator rod that everyone talks about (Thanks for the writeup Bronco Boy) so I tore the steering column apart and found that the rod was fine, I went ahead and replaced it and put some grease on all the moving parts while I was in there. I got the column back together and I can engage the starter just fine now without any binding but I can't turn the key backwards at all.
Any ideas would be appreciated, thanks.
