A D M I N in training
I have a 1970 f-100 4x4 with a 360
My problem is all the wires behind the ignition switch are cut is there a diagram i can see how to hook them up?
I searched couldn't find anything
also is there any write-ups on twin sticking a 205?
i just want to see if it will turn over how can i jump the starter solenoid off?
yeahn i just wanta see if it will crank
Disconnect the Pos cable from the solenoid going to the starter and run it right to the battery. It will crank the motor over but with no power going to the S..... or is it the I terminal of the solenoid it won't start.
Search for twin stick, I just posted a good write up someone did on twin sticking a 205.
The device mounted over on the right inside fender close to the battery is a "Starter Relay" you can lay a screw driver across the large screws if you have power and it will turn over.
All the battery cables, ignition wires and starter wires etc. are connected there.
:thumbup
