FSB warrior
spaustin889 said:
i think the shackle flip gets rid of the use of blocks
It gets rid of the angle wedge
depends on how good of condtion your springs are in,
Yes, or you can hit a J/Y and look for newer model with less miles if yours is an 80's
they are probably sagging a little and are squeaky and maybe evena litle rusty
Wouldnt want rusty springs;)
read between the lines:thumbup
is FSB'd out
cuda_killa said:
If I use Sky man. shackles for my lift, I don't need new leafs correct? Are new leafs worth it?
How much lift are looking for? If you want more than 4" in the back, you'll need an AAL, block, or new lift spring pack along with the flip.
Not always. If the pinion angle is not correct without the wedge after the shackle flip, the wedge can be put back in to correct it. Just depends on how the pinion sits after the flip is completed.
