I am replacing the stock 302 in my 90 FSB with a 351 out of a 90 fsb.
Mechanic has finally dug in and found that cam, distributor, water pump, are bad. Already replaced everything along with flywheel, torque converter, except the cam just found out this morning.
I need a cam, nothing fancy just a stock cam. Its my dd, will see some offroading, but gently.
I am looking online at summit, and a few others, but wondering if anybody knows a good place to get a stock cam at a good price:thumbup
Try a mustang roller cam. There is also a thread on here to find a cam for efi trucks written by fireguy. That will tell you everything you need to know and what brand has wha, at what price.
Satyr of the Midwest
He can't use a roller cam & lifters without a conversion kit. An engine from a 1990 anything is going to NOT be an F4TE block, i.e. it won't be roller-ready. If he needs a factory replacement cam for the 5.8L, which really isn't too bad, then I'd suggest finding a factory replacement part number from an OEM. That means go to federal-mogul.com, check out their online catalog for cam & valvetrain parts under SpeedPro (I think), and you should be able to find a part number. If not, just go directly to RockAuto.com and they should have the number available. It's always a good idea to check with the manufacturer first, IMHO. I wouldn't expect to pay more than $120 for a cam & lifter set. Stay away from Summit's stuff if you need this to be reliable. They sell racing equipment, which usually means no guarantees, and no serious R&D to make sure it's going to last like the OE stuff has to.
Thank You:thumbup Thats good advice. At this point, I am not in a position to upgrade. I do want a dependable daily driver, thats why I took it to a shop in the first place.
I read your writeup fireguy, a lot of good info. What I got out of it was that untill I am ready to upgrade my heads and exhaust, its pointless to upgrade my cam. I am not in a position to upgrade yet, business is slow till mid March.
I just want a DEPENDABLE dd. soon:beer
I had checked out summit. I will check out federal mogul, and rockauto to see what they have.
The Lightnig guys are using Mustang HO cams in speed density with no probs.. go to www.nloc.net and search the Gen 1 boards.. and check their classified ads for a deal one one..
