Satyr of the Midwest
Hey all,
I've pretty much established that my ABS pump motor is bad, having gone through the entire Ford service procedure to diagnose the problem, and just plain sticking a DVOM across the motor terminals. Code 63 was pulled from the ABS ECU, all the grounds, relays, wiring, and connectors were checked as well. The REAL problem is that I'm a po' azz student, and I'm in no position to fork over $500 for a new one; at the same time, I'm a stickler for having a fully-functional vehicle, not to mention a safe one.
My question is pertaining to the ABS electric motor itself. Every Ford publication I can find says that the motor and hydraulic controller must be replaced as an assembly, which I find to be completely :banghead . There appear to be some tabs holding the motor's casing onto the pump body, and they look fairly easy to bend out of the way. Dare I do it, and possibly save tons of $$$, or am I opening Pandora's box here? My theory is that due to its inferior design, water entered the casing and corroded the connections (this Bronc sat for a while). BTW, there is infinite resistance (open) across the motor's terminals.
If I didn't make it clear, it's a '93 w/ 5.8L, factory EVERYTHING. The truck only has 109k on it, and only a couple of small rust spots. Only down side is that it sat still for a while; almost everything else works great. I love this truck!
Banned
No, you can't fix the motor. Shop the junkyards. I have a complete 4WABS MC, booster, HCU, & lines (still assembled) that I'm planning on putting in my truck someday, so they're out there if you look.
if you can wait until the summer im getting rid of the entire assembly and replumbing the entire system i got rid of the abs with the axle swap so if you want it cheap let me know
Thanks for the replies, guys.
voelker, I just might be able to wait until summer. Just depends on how impatient I get. Hehehe. No, seriously, I appreciate the offer and if I still need it by then, you will get a PM from me.
On the other hand, I have an itch to scratch. I just HAVE to get that black casing off the motor to see how she looks at least! Damn fan shroud and p/s line are getting in the way at the moment. I'll keep this updated if I make any significant findings; maybe I'll take some pictures.
FSB warrior
On my taurus I just changed the CPU, and it said that the entire system should only be serviced by a qualified technition.... All it was was 6 screws and 2 connectors... Mine was 500 bucks at Ford, and I called every junkyard in my state, and 2 in Mass as well but they didnt have any 01 Taurus's with Traction control and ABS so I had to choke up 500 bones.
Can you buy just the CPU???
