It started last night after riding around. When my truck warms up and after riding for a bit it starts cutting out when you give it throttle and only apparently under a load because it seems to idle fine and in neutral if you give it throttle sounds fine and does not cut out. If you kill it then restart it will run fine for a bit but then continue to cut out not allowing me to get over 10 mph. I am thinking something along the lines of an injector problem but not quite sure. Any input is greatly appreciated. By the way its a 95 with the 302.
codes:
Based on www.fordfuelinjection.com library with CM, KOEO & KOER Chart.
55 MAF sensor - voltage issue.............
56 TOT - voltage issue ............
65 Over Drive OFF switch voltage issue ........
MAF Sensor - CM continous memory issue.......
Start here, you made need a mulitimeter to test for voltage or resistance in the wiring or parts etc. Haynes Manual for procedures.
Good Luck ~ :thumbup
Well I checked fuel pressure it was fine. The codes it shows are 55, 56, and 65. Any help?
Those aren't your codes.
Your 95 uses 3 digit codes.
