1 - 4 of 4 Posts
I drive a 93 bronc, and the other day when i tried to open the drivers side door from the inside, i heard a snapping sound and the handle came loose in my hand. when i got home i removed the door panel and found out that the handle had ripped completely off of the door. The part of the door that holds the handle is destroyed. should i buy a new door, or should i attempt a repair?
User that is Registered
You should repair it. You can put a big washer and a nut on the other side of the metal in the door. Or, if you have access to a MIG or TIG welder you can weld the mechanism directly to the door (this is my personal favorite way to deal with the problem).
1 - 4 of 4 Posts
