1 - 18 of 18 Posts
What is the opinion of the Carpet vs. Rubber Floor Mat vs. Line X. I guess I am leaning toward Line X but the lack of insulation from heat and noise is my biggest concern...The Rubber Floor mat is looking better.
BroncoXpense
rubber floor mats will hold water underneath them...Id go lineX
I like the idea of Line-X also, but the cost is a question mark for me. Has anyone done this or priced it?
there's tons of info on it bed lining. do a search. I have the rubber floor mat in mine and the floor is rusted underneath
I got a price estimate of around $400.00 if I go black and that was everything from the front to the back and up the sides as high as I wanted. Color matching would be another $150.00 which I like but kinda pricey! :shocked
BroncoXpense
dont pay someone to do it if thats what your referring to, thats an easy job to do by yourself. Save a lot of labor money. If u feel safer letting some shop guy do it, go for it tho.
The Anti Yam!
I POR-15'd my floor, then laid 2 layers of FatMat/Peal and seal, a layer of good carpet pading and my pristeen looking original carpet over it.
Verry plush :toothless
carpets over rated..:goodfinge (I wish I still had my carpet alot of the time..it atleast covered the rust holes in the floor)
Discussion Starter · #9 ·
If I could figure out a way to keep the carpet clean with a blow gun instead of a vac...I'm in...I just do not like putting new carpet in so that I can trash it with red mud...:whiteflag
search here for "Herculiner" and/or "Durabak." both do it yerself products that have been used by members here.
gonna Hurculine mine. did my bro-in-laws race truck (bracket drag) and it came out great. and it cut down on noise ALOT.
Engineer
I want to linex mine but my truck needs a lot of work before that will happen
The Anti Yam!
Back in 98, I had 6" of liquid red clay from a hole I was stuck in flowing over the floor board. Literaly my foot was under water to work the gas pedal.
Afte 2 hours, the CJ-7 finaly worked me out. Then I pulled the CJ-7 and the YJ that was with us out of the same hole.
Next day I took the cab carpet out, washed it with the hose, put it back in and it was good as new.
What.... It wasn't always a Mall-Crawler.
Hell I'v blown up 2 engins in mud holes :toothless
I like the carpet for the comfort and I live in the desert so mud isn't a problem, sand can be vacuumed. but from what you saying about being in mud I would probably go with one of the spray/roll on liners that can be wiped clean or even sprayed out plus solve the rust problems I won't have. eventually i will probably do a liner underneath my carpet like gacknar to eliminate some road/exhaust noise but i need the exhaust first
Horizon said:
I'm doing both actually. I don't care much for the looks of a liner, but respect the need to stop rust. As such, I'm using the Duplicolor spray/roll in liner to seal and sound-deaden ($40) and covering that with a rubber mat ($215). Best of both worlds IMO.
http://www.duplicolor.com/products/truckbed.html
http://www.auto-interior.com/ford1.htm#Bronco
~Jeff
i would not waste my time with the duplicolor. i used it over new primer on a roll bar and it flakes off way too easy. i am glad i did the bar before i used it in the truck. i went with the herc kit ($79 at pep boys) and am very happy. it stuck like glue to the rust bullet i put under it.
Call Me Ace
i think the idea of doing a liner and then the rubber mats is a great idea! i might have to run with that one...
ace
herculine man all the way.
I have it in mine and it looks pretty savvy
wipes clean, but only prob w/ carpet is mud and chit sticks to it all the time and its a bitch 2 get off... bed liner you can wipe/ spray clean but its loud as hell if you have some loud exhaust
I'm in the process of Herculining mine. Its pretty quick and easy. Don't pay somebody to do it for you for $400 when you can do it yourself for $60.
Thats right, I said $60. PEP BOYS has a $20 rebate for the Herculiner roll on kit. Of course I threw out my reciept before I realized it. :banghead
1 - 18 of 18 Posts
