southern Pride said:
im strippin the hole inside of my 1990 bronco and i was wonderin if i could put any seats and any dash back in it because i have a friend that works at an auto salvage so i can get pretty good deals
You have a hole inside your Bronco?
J/K, but I really don't understand your question.
i think he means the "whole" or "entire" inside of the bronco.
in answer to the question, yeah, i'm sure you could fit any of them in there if you really want to do some fabrication. personally i'd go with a direct replacement, but wires scare me.
· Call Me Ace
ooooooh- i see what hes saying.
correct me if im wrong- but you have to use a dash somewhere between like 86-91? might be off on that one...
as for the seats- there are guys using infinity seats. its just how much work you want to do on the brackets...
ace
in my 80 bronco I used first gen. rx7 seats, they had lumbar support, highback, and were free, all I had to do was run some square stock steel across the bronco seat mount, then attatched the rx7 seats to those, it was a really easy job, I was 15. measure twice, drill/cut once.
