thats the best name i could come up with it, what it does is stops the hot coolant from flowing through the heater core. I dont know if this happens in other trucks but in mine the hot heater core would cause convection inside my truck letting hot air to flow around inside, not very satisfying during summer or if the A/C is on.
the basic hardparts are:
-the valve out of a jeep, almost any jeep has one
note:these "valves" come in different orientations to where the bottom hose connector points so watch out
-four hose clamps size at least 1 1/4"
- about 15" of vacuum hose and a T or Y connector and two vacuum connectors
Its a simple install
- make sure you dont have coolant in your heater core lines
- fine a good spot for the bypass (valve) and cut the line for the bottom inlet out of the heater core
- the top line from the heater core should be about 1'' shorter for the valve to stand up right
- cut the other half of the coolant lines to length
- now cut the vacuum line going to the inside air/ outside air actuator and make a 3 way connection to include the new valve
here is that little neat "valve"
the tools i used
test fitting the hoses for length
the vacuum splice
and here it is done
thats it nice and simple it "bypasses" the heater core when you turn the outside air off, as it says on the control panel for A/C use:thumbup
the tools i used
the vacuum splice
and here it is done
