I was wondering if anybody has any Idea what engine towers and mounts I would need to install a 302 in a 79 bronco? Or what combination will work with modification.
i have a 79 bronco and i did the same thing also i put a 302 engine in it .i recent had a 80 bronco and i just switch everything
from the 80 to the 79 even though it was a lot of work
If only I would have saved stuff back then I could have given you the entire package you need....I took a 302 out of my 81 since it had a broken piston skirt 10 years ago. I had a 400 and a big C-6 so that is what I put in. All of the alt., P.S.pump, A/C brackets has to be swapped as well as the engine mounts, but if I remember correctly it was pretty much plug and play. I used the same PS pump and alt but the brackets were sourced from an earlier one.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Bronco Forum - Full Size Ford Bronco Forum
A forum community dedicated to all Ford Bronco owners and enthusiasts including the new 2021 Ford Bronco. Join the discussion about specs, photos, news, pricing, modifications, maintenance, and more!
