1 - 10 of 10 Posts
I have a 95 bronco with a 2.5" lift . the alingment shop says I need drop brackets to properly aling it. My question is; Do I attempt to install the brackets myself or should I pay them to do the install? I already purchased the brackets from Tuff Country along with new urathane bushings. If I do the install myself whats the easiest way, and what special tools do I need if any? The Shop says they have done them before and it takes them about 3 hours( $65/hr x 3 = $195 ). Is it worth the money for the shop to do it, incase there are any problems. Any and all help would be great.
FSB's Bastard Child
Andy351 said:
the best way to get the rivets off is to grind the heads off, drill a couple small holes through the rivets and then knock them out with a air chisel.
at least thats how i did it. :shrug
Show off. :iiss
Screw the Jeep Thing
I don't think he was showing off I bet he's just to weak to hit a punch hard enough to make the rivets come out..
Oh I did try the air chisel to knock mine out. But I don't tihnk my little compressor puts out enough PSI. Thats the last time I let me old man by the compressor!!!:(
negative creep
well, when you have a hernia and a thrown out back, yes i am too weak. :brownbag
i also had a compressor sitting 10 feet away from me and a $10 air chisel to use. so why not. and there wasn't a lot of room to swing a hammer since i didn't move the beams out from under the truck. if you can move the beams out from under the truck, it gives a lot more room to work.
1 - 10 of 10 Posts
