Does a 96 F-150's wiring harness have the hook up for the tach already in place even on vehicles without one? I want to know if I could put an instrument panel from another Fullsize truck with a tach on my truck and it work.
Charlie don't surf..
'92 Ford Bronco XLT
Yes it should.
When i did the searching on my 83 a few places said yep swap the cluster and be good to go. i swapped the tach and the printed circuit bord from a cluster with a factory tach and it still working fine. ...mike
yep, it sure does
Banned
For a DIRECT swap, you have to get a cluster from a '94-96 F150 only. '94-96 Broncos have a 4WABS light instead of ABS like a pickup; older ones & heavier trucks don't have an AIRBAG light, so their wiring is slightly different.
ok, thanks yall. if i can find a good one i'll do the swap
