Needing to repair a thread on the rear passenger side of the intake manifold. First question is if I need to remove the manifold before drilling. The hole seems to end outside of the block so not worried about trash.
Second question is if I need to still replace the intake gasket. The gasket is brand new, but I noticed I had a lot of smoke coming from the engine and having trouble starting the engine.
I figured I needed to eliminate this thread as the culprit. When installing, I was only able to slightly tighten the bolt (not to torque spec) only a little before no longer tightening. I tried to see if I could get away with and now not so sure.
This is an 82 Bronco with a 351 Windsor.
Here's a pic for reference. Problem hole is one with screwdriver in it.
