1 - 14 of 14 Posts
doyou want to trade fort a mustang intake?
the truck intake is the same lower as the holly lower and thats made for big time hp...stang guys will use a truck lower and the holly upper (its cheaper then buying the whole thing from holly).....the stang intake is real restrictive but i guess it would give great low end power
Ex Navy Nuke
I have and so have a few others. If you have a 351 an Edelbrock or GT-40 intake will definitely be an improvement over stock. If you have a 302, just leave it alone it already flows good. Don't know about a stock Mustang intake but a Mustang style Edelbrock is a big improvement over the restrictive stock 351 truck intake. You will find alot on this if you search. there are some pics of my setup on my Supermotors page too.
Well I ask this because I had a 96 F-150 with a 5.0L HO Mass Air and the engine was really weak.It was the same engine as in the stang.I was told by some 4x4 guys that the stock intake with the twin TB was flowing to much air for the engine and a way to fix that was to swap to a 5.0L stang intake with the smaller but longer runners with a single 60mm TB and that will give me torque in the lower end for street or off road...I just wondered if this was true.
I have a Cobra intake on a 5.8L roller truck engine that is in a stang that just rocks, and I have drivin my Dads f-150 with a 5.8L in it and it has alot of low end torque.......but the 5.0L or 302 just has nothing.
aka: kemicalburns
the holley upper will not fit the truck lower.
Ex Navy Nuke
Too much air :scratchhe . How about because the 302 is just under-powered for a big truck, it's not a Mustang. The truck 302 intake already flows good. If you want more power put in a cam and put on a free flowing exhaust. Does it really make much sense that putting on a smaller TB will make it run better? Or putting on an intake that's designed for a small car instead of the one designed for the truck?
aka: kemicalburns
yes your right, had to do some research. not sure what i was thinking. :banghead
The Anti Yam!
You where thinking about those round ports on the 351w lower, they dont work with nothin. :toothless
1 - 14 of 14 Posts
