1 - 1 of 1 Posts
Just an iPad mount I designed for the interior of my Bronco. The iPad was my wife's, but since I bought her a new one as a Christmas present last year, this has been sitting on the shelf. Turns out, it has a GPS chip, so I'm planning on using it as a Map or GPS unit.
The part that holds the iPad is her old protective cover that was beyond worn out, so I dismantled it and used it as part of the mount. The ipad can rotate 360 and each arm joint can move 180 degrees. Right now, its mounted to my desk while I test the durability, but will eventually be bolted to the center console in my Bronco.
And yes, it will hold the weight at full extension from the ball joint.
170322
1 - 1 of 1 Posts
