1 - 8 of 8 Posts
1995 5.8, 2.5" Rough Country Lift, Extended RA's, 4.10's, 33" BFG's
Hey all!
Does anybody know the name of the gray color in a 95? Thanks
J
Cool! Thanks
How about SEM? What is SMP dye?
yo, My bad typo; I meant SEM. :thumbup
SEM Vinyl & Leather Classic Coat™ Chart, Ford Colors; "...uses advanced technology to provide superior adhesion and flexibility when changing or restoring the color of most leather and vinyl. CLASSIC COAT is a fade resistant coating that won’t chip or peel and is available in many of today’s popular OEM colors..."
Source: by SEM
SEM Vinyl & Leather Classic Coat™ Application Instructions
Source: by SEM
SEM Vinyl & Plastic, Carpet and Velour Color Coat Chart; "...VSC-CC Color Coat is the industry standard for vinyl or plastic restoration. It is fade restistant, flexible and is a permanent coating..."
Source: by SEM
SEM Vinyl & Plastic, Carpet and Velour Color Coat Application Instructions
Source: by SEM
SEM Information, Review & Source by BLOODSWEATSTEEL (Bigfoot) & Sixlitre (Malcolm H, Eddie Bauer) at FSB
VHT Vinyl Dye™ Review in a 92 (pics are gone)
Source: by 92Pony at FSB
Vinyl Dye-Paint Pics & Info in an 86
Source: by Sixlitre (Malcolm H, Eddie Bauer) at FSB
our pal Malcolm had his local auto paint store mix up an aersol can for him that matched..!
VHT Vinyl Dye™ Overview & Colors; "...for vinyl and carpeting restores or changes the color of any vinyl upholstery, seats and trim, or the "short nap" carpeting found in today's cars, boats and watercraft. It is ideal for use on stiff or pliable vinyl, simulated leather or plastic. It is extremely resistant to cracking or fading. Careful preparation is essential and all traces of dirt, silicone products, vinyl and rubber protectants, oils and greases must be removed. Incomplete preparation will not produce a satisfactory result. Applications: Carpet, Vinyl Dashboards, Vinyl Seats, Trunk Carpet, Soft Tops, Untreated Leather. Finish: Satin. Dry Time: Dries to the touch in 30 minutes. Dries thoroughly overnight. No curing required.
Source: by vhtpaint.com
Krylon Fusion for Plastic® Overview & Colors; "...No sanding or priming required. Bonds easily to most plastics, PVC, resin and more. Fast dry; fully chip resistant after 7 days. Features EZ Touch 360® Dial Spray Tip. Dry to Touch 15 minutes. Dry to Handle 1 hour. For use with Wood, Metal, Wicker, Wrought Iron, Plastic, Hard Vinyl, Glass, Plaster, Ceramic, Paper, Paper Mache..."
Source: by krylon.com
Krylon Fusion for Plastic® Application Instructions
Krylon Fusion for Plastic® Application in an 84 by jkorbes at FSB
Dupli-Color® Vinyl & Fabric Application in a 95
Source: by BurlyQ at FSB
Dupli-Color® Vinyl & Fabric Coating Overview & Colors; \"...Flexible self-priming formula. Resists cracking, flaking, and peeling. Dry to touch in 30 Minutes / Handle in 1 Hour...
1 - 8 of 8 Posts
