1 - 13 of 13 Posts
So, carpet, door panels, dash pad. I can find all of those new.
But what about things like the main dash piece, kick panels etc? Cannot find those except Ebay or junkyard, which I would prefer to get new if available.
Or is painting the only other option?
Same for the two wood trim pieces for the gauge cluster and center stack, for the center all I can find is the XLT one, whereas if I replace it (the two screw tabs at the top are broken) I would at least like to replace it with the eddie bauer that it is.
Addicted to Junk
JY is the only option for the dash pieces. There is a dash pad available new, but only in black. What color exactly are you looking for?
I have a near mint 85-86 XLT wood radio bezel if interested. Has the badge and all. I do have an xlt ranger badge for that spot too.
Yo Jimmy,
"...Typically interior colors are a vinyl paint in late model vehicles.. Older vehicles with metal interiors use the same paint used on the exterior. Interior colors are not color coded on the vehicle anywhere so you have two choices. You can borrow our color books or you can also go by a body shop with interior color chips and have them tell you what color code you have. Once we know the color code, we can make the paint..."
Source: by paintscratch.com
SEM Vinyl & Plastic, Carpet and Velour Color Coat Application Instructions @
Source: by SEM @ Literature | Training & Resources | SEM Products
ColorBond Application in an 86; "...cleaned the entire thing with purple-power twice. Then I lightly wiped it down with acetone. Then, just to make sure the factory paint did not cause a problem I wiped a section down with acetone until the factory coating was removed and it was down to the bare plastic. This is the lighter area in the picture below. Unfortunately this did lighten the texture a little. Took 5 mist coats to cover. The area with the factory paint removed was harder to coat, making me think it was sinking into the plastic, but sat on top of the factory paint everywhere else. Then again it may have just been the fact that that area was lighter. I let the Color Bond cure for 48 hours and then did a scratch test. I can not scratch it off with my fingernail anywhere and it takes a serious effort to scratch it off using a penny..."
Source: by Gacknar (The Mall-Crawler, Jeremy, "Big grey megga beast") at FSB
VHT Vinyl Dye Application in an 82
Source: by mickaila at FSB
I am planning on switching to black and gray two tone interior. I have found some grey/black gauge and dash bezels instead of the woodgrain, but I may not mind sticking with the woodgrain, saw a picture of one and it provided a nice contrast with a mostly black interior. Right now it is tan.
I Was looking for a picture of the one I'd seen, it was one that has been for sale locally for a long time, but looks like the listing was pulled within the last few days.
Addicted to Junk
This is for 80-86 right?
They made the woodgrain bezels and gray/black bezels. I think nice woodgrain ones would look sharp with black and gray.
My dash is gray with black painted bezels. And some custom gauge work...
Reactions: NYFSB
yeah, for an 86. I need to go check my 82, but pretty sure it has zero original dash trim components. pretty sure the main gauge cluster is all a metal panel with aftermarket...been a while since I looked.
I am thinking black dash pad, black lower door panels and black carpet, medium gray main dash, upper door panels but black armrests, kick panels and other interior trim, black and gray seats, and gray mouldings around the windshield...maybe black on that.. If I ever get the body repainted, I'll go two tone black and grey, with the black in the center and grey above and below.
I think the only thing you will find new is the carpet. I saw a guy on E-bay selling Tan door panels in mint condition for $500 each, I sent him an appropriate Best Offer and he told me to eff off. A week later he sold them at full asking. It took me over a year to find a perfect dash pad and at that point I paid what was asked because there are very few alternatives. If I was you I would pick up some scrap interior pieces in the yard and try painting them and see if you're happy with the result..
only things that must be replaced if things can be painted is the carpet, door panels, headliner, and dash pad. So I guess I'll just have to try the painting trick with everything else.
Addicted to Junk
I come across em all the time in the yards in f150s. Never seen a good dash pad of any color. Door panels are the same way, though slightly less brittle. I need a dash pad myself. If you touch the top, it cracks.
I just scored what would be considered 99% mint condition 80 set of woodgrain dash bezels today. Factory two post radio style and the digital clock that goes with it. XLT Ranger badge.
U may want to rethink the black carpet in the cargo area. It's very hard to find replacement carpet with uv protection and it will fade in a couple years time unless you're getting as custom fit cargo liner that covers the majority of it.
Repainting interior panels isn't that difficult and lasts as long as you do proper prep. Or you could even use something like sem dye which from why I hear is really good stuff. Idk tho cause I repainted all my interior panels. They turned out really well. U can see the process I went thru and how it all turned out in my build thread Broncmoms 82 resto
I ended up painting my interior. I used colorbond. It was OK. Its been 3 or 4 years since I painted it and its held up really well everywhere except the top of the dash. I also used their satin clear coat that they say helps protect it from UV. Its definitely not bad. It just looked better when it was freshly painted..If i had it to do over, I would use SEM.
Discussion Starter #12
I'll be rhino lining the cargo area. the bronco is also replacing my pickup so it'll be hauling stuff pretty often, besides ass. she's certainly not the fastest thing on the road by any means.
Reactions: BroncMom
Gotcha...I used monstaliner in my cargo area. I thought it had a better texture. I liked how it was formulated more, and it came in an easy roll on or spray application which meant less taping off.
1 - 13 of 13 Posts
