Newbie to this forum here. I would like to start off with, I'm a avid Ford man. I've owned two BronoIIs, two FSBs, and currently own a 91 F-250 7.5l and a 91 FSB 5.8L. I'm just saying I love Fords and Broncos and I love this website.
Problem: 1991, 5.8L, 4WD, Auto
Ok so I've been working on this problem for about a year now. It's sluggish off the line sometimes, I give it full throttle and it bogs down and sometimes backfirers into intake. (Remember this problem is very intermitent) Normally after doing it for a few seconds it goes away and vrooom full power again.
Somedays it's worse than others. There are times where it will bogdown backfire and the more throttle I give the worse it gets. shut the truck off start back up and same thing bog down no power and backfiring. and when I say no power i mean none truck won't move in gear. (that reminds me 99% of the time it only acts like this in gear, if i put it in neutral hit the gas it revs right up. ten minutes later I'll start the truck and it'll be fine.
other days I don't even notice it and it runs great.
Now that the cold is here it's worse than ever I can't even drive it. It's unsafe.
Here's what I know. I've pulled codes and nothing. and I know the code thing works I've used it in the past for a map sensor fail. checked compression.
I've replaced - PCV, fuel pree regulator, sparkplugs, wires, personally rebuilt distro, cap and rotor, fuel filter, idle air control valve, tps, air filter, fh relays
I've ohmed checked the tps, map, egr,
I pulled the fuel pump put it directly on a battery to see how it runs and it seem to run great.
I really appriciate any help. I'm stumped
Matt
Matt
