1 - 8 of 8 Posts
1996 Bronco 5.0/E4OD/BW1356
Yup - seems like only Ford had Hi-Pinion axles. Much stronger in forward gears, not as strong in reverse gears. Lo-Pinion is better in reverse gears, weaker in forward gears... I drive forward more then I drive backwards - Hi-Pinion just makes sense.
Former owner of Shadofax
I'd be more interested in the nice height advantage of the driveshaft than possible strength. Driveshaft stays up higher on the high pinion, and the angularity as you lift the truck is much better starting higher.
Thanks. I know it is a D44 cause it is stamped all over it. I am sure it is a low pinion from what has been said here. I am not sure what it came out of but i spent an hour in the JY looking at wagoneers and the only one I saw with a left side diff was a cherokee. but it was the full size type basically a 2 door wagoneer. Anyway thanks lots. I am probably not going to use the housing but it was a really good deal.
The early Bronco D44's were low pinion - could be one of those. It is narrow and low pinion - only Ford D44 that I can think of that is Lo-Pinion....
Mid to early 70's f series axle were low pinion also.
that's right. '76 highboy F250 with leaf D44 was also low pinion as I recall, whereas you move to the '78 F250 leaf (HD) 44 and it's high pinion.
1 - 8 of 8 Posts
