yo JOHN
for wheel cyclinders, Parking Brakes,
Ford advises to;
Caliper
Clean all metal parts with isopropyl alcohol. Then, clean out and dry the grooves and passageways with compressed air. Make sure that caliper bore and component parts are thoroughly clean and dry prior to assembly.
Use denatured alcohol to clean component parts. Allow the parts to completely air dry. Apply Ford High Performance DOT 3 Brake Fluid C6AZ-19542-AA or DOT 3 equivalent fluid meeting Ford specification ESA-M6C25-A to the rear wheel cylinder internal parts before assembly.
Brake Shoe and Lining
Apply Disc Brake Caliper Slide Grease D7AZ-19590-A or equivalent meeting Ford specification ESA-M1C172-A to the threads and the socket end of the brake adjuster screw
Brake Shoe and Linings
Inspect brake shoes and linings (2001) for wear. If the lining is worn to within 3mm (1/8 inch) of the shoe, replace all four shoe and lining assemblies (complete axle set) on front wheels as required.
Do not attempt to clean or restore any oil- or grease-soaked brake shoes and linings. When contaminated brake shoes and linings are found, they must be replaced in complete axle sets.
WARNING: DO NOT INHALE DUST FROM BRAKES OR ASSOCIATED COMPONENTS. INHALATION OF DUST CAN BE HAZARDOUS TO YOUR HEALTH. COMPRESSED AIR OR BRUSHES MUST NOT BE USED TO CLEAN BRAKES, BRAKE DRUMS (1126) OR ASSOCIATED COMPONENTS. A VACUUM CLEANER (ROTUNDA BRAKE/CLUTCH/SERVICE VACUUM 164-R3600 OR EQUIVALENT) EQUIPPED FOR THIS PURPOSE SHOULD BE CAREFULLY USED TO REMOVE ANY DUST. ADHERENT DUST SHOULD BE REMOVED WITH A DAMP RAG. ANY DUST SHOULD BE CONTAINED IN A SEALED AND LABELED BAG FOR DISPOSAL. WEAR AN APPROVED HIGH EFFICIENCY CARTRIDGE OR AIR LINE RESPIRATOR AND USE EXTRA CAUTION TO AVOID BREATHING THIS DUST.
Rotor
Grease or any other foreign material must be kept off the brake shoe and lining (2001) surfaces of the rotor and external surfaces of the front disc brake hub and rotor (1102) during service operations. In handling the front disc brake hub and rotor and disc brake caliper assemblies, avoid deformation of the front disc brake hub and rotor and nicking or scratching of brake shoes and linings.
CAUTION: Never reuse brake fluid that has been drained from the hydraulic system or has been allowed to stand in an open container for an extended period of time.
Use Ford High Performance DOT 3 Brake Fluid C6AZ-19542-AA or equivalent DOT 3 fluid meeting Ford specification ESA-M6C25-A.
