Dead Horse
i have bench seats. a member here is supposed to come down soon to swap. ill be getting his leather power seats, console, and rear seat. is my truck already wired for power buckets? even though its a bench seat, like is there a plug hidden under the floor somewhere that i can just plug the seats into? if not, how hard is it to wire them up? thanks guys
btw, the reason i asked, is because i had a 2wd explorer, and where the push button 4x4 would be on a 4x4 model, the wires and plugs were clipped to the back of that filler plate, like it was pre wired for it.
No it probably is not prewired though im not 100% sure. You just need to wire it to a 12v constant and a ground i think
Dead Horse
ok thanks for the quick help.
i could wire it up fine if it was just 12 volts
i figured it would be different voltages for diffirent things, like 4.5 volts for the seat motor, thats just an example of what i was thinking.
hopefulyl someone else will chime in and give a deffininte
Do you have a fasten seat belt light on your dash that lights up? If so your probably good as far as wiring. My bucket seats in my 94 have only a two wire connector going to each seat and I have the power lumbar also.
Dead Horse
i do have a connector, but my connector doesent look like that one in the picture. its got 2 wires though, just the plug looks different
