1 - 11 of 11 Posts
i want to raplace the captains chairs with a bench seat for my '94 bronco.
were they made in that year? does any one know where i could find one if there is such a thing.
I'm almost certain someone from these forums (if not multiple people) put an F-150 bench in the Bronco, you just have to drill for the mounting brackets.
Have you searched? As I said, I'm almost positive someone here has done it before.
Former owner of Shadofax
Yea, just look for pics for newer year F150s. IIRC at one time I was interested in the truck 60/40 bench seat. Would be easy to swap over.
What color is your interior?
cool thanx for advice i didnt think of using an f-150 ,i'll keep poking around for someone that has actually done this
w.h.
I bolted the back seat from a crew cab F350 in mine. There actually the same as the front seat, just in a lot better condition.
Look for a seat from an extended cab truck, because it makes getting in the back a lot easier
awsome i've been trying to figure out how to fit three peopel in the front of this truck since it's soooo wide. steve thank you for that info. i would never have guessed that the holes where there. but you said the bolts will self tap? i've only heard of that in sheet metal screws. the seats aren't held in with only sheet metal are they? and does that mean that i have to use my old seat bolts? are there enough?
Discussion Starter · #8 ·
Steve83 said:
The floor is ready for a bench. Just pull the rubber plugs out of the holes & your bolts will self-tap. Put the plugs in the captain's chairs holes.
thanx steve , yeah i was unsure if this was at all a possibility without having to do modifications to either the bench or mounting. now will i be able to use a split bench or will it have to be a one piece deal?
Discussion Starter · #9 ·
does the back seat fold over more? and will the bench seat slide like the captains chairs do? thanx for the help
w.h.
Garage kept
i've got a 83 with seat out out of a 94 xl f150
1 - 11 of 11 Posts
