1 - 11 of 11 Posts
got a chevy 1ton axle but is not a 14 bolt it is a 10 bolt and is 8 lug off a 68 chevy would this axle be any good to swap out with not sure of gear ratio yet but any help on what it is and it any good would be nice
Stuck like a MoFo
without being 100% positive i would say it has less splineage than something of later era....plus it prolly doesn't have a good selection of aft acc's
Former owner of Shadofax
both true. This is actually an 8 lug fullfloater 10bolt? later chevy 10 bolts suck. And I'm not sure they were making 8 lug versions (probably why the 14 came out). Any pics of this axle, so much easier to judge.
why not just stick to your FORD? thats like trying to mix pudding with ice cream
Harmful if swallowed
Because commonly avaliable GM rear axles (and front d60 axles for non-ford apps.) are cheaper, easier to find, have more aftermarket options, and often times have interchangble parts over a wide range of years.
Of course, sterling rears are a good option too.
And as far as the rear out of the 68, is it possibly a Eaton?
shibby
If it's an Eaton, it's good to run. You'll just have zero aftermarket support for it. I bought a factory geared 5.13 pumpkin to bolt into mine and welded the spider gears up.
When you welded it up, how did it compare in beef to all the other axles, like the 14 bolt or D70? I have never seen inside one.
They also came in old Internationals. This one it a 1950
shibby
I dunno, never seen the inside of a 14 bolt or dana 70. The Eaton can use the same locker/spool as a 14 bolt, just have to change the axle shafts to 14 bolt as well. It's a one-piece housing which I like and very easy to weld on. I was able to use 14 bolt disc brake brackets without any problems. The Eaton axle overall is much lighter than a 14 bolt.
1 - 11 of 11 Posts
