hey guys, i got my truck on a lift today to check out out which side of my rocker covers is leaking oil,..... and then it dawned on me,...... well,.. it kinda "dripped" on me!,..... yes my old friend the rear crank oil seal has once again p!ssed on me from above!,... i ran the motor to check it was nothing too bad,.... seemed to be a tiny trickle coming from the seal,.... but then i noticed the tapping sound also coming from the bell housing area,...... so i pulled the rubber inspection hole bung out, grabbed me a torch and had me a looky,.......... i was horrified to see that the shaft between the clutch and the back of the gearbox/slave cylinder end,...appeared to be running off- centre,.... hence tapping / knocking noise!,:cry.... why would this do such a thing,..... any ideas? has it happened to you?,.... it seems to be the cause of the leak,....:whiteflag
