i am going to run extended radius arms so i need something to mount them to. i looked and with the arms that i have they will hit right between the tranny crossmember and the transfer case. i may have to trim the flange on the tranny crossmember, but it will tuck in there quite nicely and should be ok til i can afford a doubler and have to redo that part.
here is my fab question. will 2.5"x.25" wall square tube be enough or should i use 3"x.25" square? its only a 35" span across the frame rails at that point. if the .25" isnt beefy enough, i could weld it to a flat plate of .25"x3" flat stock for more beef.
