1 - 8 of 8 Posts
Is it normal for this hole to just be open like that on the bottom of the E4OD, or am I missing a plug or seal or something?
mines like that too, theres supposed to be a plug there.
MARBLE GARGLER!
the plugs get old and fall out... i just call it a little extra cooling.
x3 on the plug, mine is still there. looks like someone has been into your tranny. That torque converter is blue and the tranny is really clean. You had some work done recently?
Yeah, it was rebuilt less than 10,000 miles ago.
maybe a trip to the junk yard? or just make your own.
yo,
Ford even took the time to post a TSB on it!
Torque Converter Access External Dust Plug May Become Dislodged TSB 02-21-1 for 89-96
Source: by Ford via thedieselstop.com
TSB 02-21-01 E4OD/4R100 Torque Converter Access External Dust Plug May Become Dislodged
Applicability:
1989-1996 BRONCO
1989-1997 F SUPER DUTY
1989-1998 F-250 LD, F-53 MOTORHOME
1989-2003 E SERIES, F-150
1997-2003 EXPEDITION
1999-2003 SUPER DUTY F SERIES, SUPER DUTY F-53 STRIPPED CHAS.
2000-2003 EXCURSION
LINCOLN: 1998-2003 NAVIGATOR
2002-2003 BLACKWOOD
ISSUE: Some vehicles equipped with the E4OD/4R100 transmission may exhibit the torque converter external access dust plug dislodging and falling out during severe duty use. This may be caused by a combination of stack up tolerance, material shrinkage over time, and loading being applied to the plug during usage or cleaning of the underside of the vehicle.
ACTION: Obtain new plug (E9TZ-7N171-A) and apply 1/4" bead of silicone sealant around entire perimeter of part and install plug into transmission case. The silicone is to be applied in the groove of the part such that when it is installed, the sealant will fill any gaps between the transmission case and the plug.
SERVICE PROCEDURE
Obtain service part E9TZ-7N171-A, F7TZ-19554-AA and general purpose degreaser such as Motorcraft Brake Parts Cleaner, PM-4. Clean transmission case casting in the area of the plug using general purpose degreaser making sure the area is free from grease and other contaminants. Apply a 1/4" bead of silicone sealant F7TZ-19554-AA to plug E9TZ-7N171-A making sure that the groove in the plug is filled with silicone sealant. Immediately install plug into the transmission case casting smoothing out any overflow that may occur during installation.
PART NUMBER PART NAME
PM-4 Motorcraft Brake Parts Cleaner
E9TZ-7N171-A Plug - Converter Access
F7TZ-19554-AA Ultra Silicone Sealant
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION: 022101A
DESCRIPTION: Install Torque Converter Access External Dust Plug - 1989-1996 Bronco, 1989-1997 F-150, F250LD, F-Super Duty, E-Series, 1998-2003 F-150, Lightning, Harley Davidson, F-250LD, Super Duty F-Series, E-Series, 2000-2003 Excursion, 1989-2003 Motor Home Stripped Chassis, 1997-2003 Expedition, Navigator, 2002-2003 Blackwood
TIME: 0.2 Hr.
Item Number MSRP Price
E9TZ7N171A $6.15
PLUG-TRANS CONV DRAI
http://www.trademotion.com/partlocator/index.cfm?action=searchCatalogOEM&siteid=318
US $7.00 @ http://cgi.ebay.com/ebaymotors/E9TZ7N171A-Plug-00-01-02-97-98-99-EXPLORER-/110540378180
1 - 8 of 8 Posts
