1 - 3 of 3 Posts
Lick my balls
maybe I'm just dumb, but I have no idea what you are saying.
blackbroncoxlt65 said:
:whiteflag
i did a fuel pressure reading on the 91 fsb w/a 5.0, koeo with fuel pressure regulator plug in 36# with fuel pressure regulator unplugged 37#,,
koer regulator plugged in 46# regulator unplugged 58# are this pressures to high?
:banghead
KOEO numbers look right, but KOER numbers definitely look high to me. Far as I know, should still be maintaining about 37-40 KOER with the regulator disconnected from vacuum, and usually around 27-30 if I recall with vacuum connected (depends on what you're getting for vacuum, fuel pressure should always be around 37-40 minus your manifold vacuum in psi, not inches).
1 - 3 of 3 Posts
