1 - 13 of 13 Posts
My work currently has a project they're doing that has gobs of steel tubing left over that I have access to. Basically, I can pile up on 3"x2"x1/8" and 2"x2"x1/8" square tubing if I want to.
Before I do, however, I wanted to make sure that if I were to create a bumper for it out of that material if it'd be up to the task. Is 1/8" walled square tubing strong enough? Or would I go through all of that work and at the first bump be bending it?
Thanks.
Thanks.
I built my sliders out of 1/8" wall and they have held up fine so far. Ive dropped onto concrete and rocks pretty hard a few times and the seem unfazed.
Diesel Gynachologist
yeah .188 wall works well along with cheaper and lighter. .250wall is overkill.
1/8th is fine for a bumper.
so if you can pile up on it I would like some. 2x2 and 2x3 comes in handy for alot of stuff.
Lick my balls
Except for the center section, where the winch will be mounted, my next bumper will be 1/8"
1/8" is plenty strong. I wouldnt stretch is more then 4 feet, if you plan on pulling from it, hitting stuff...like shopping carts:chili:
Lick my balls
I would not use anything less than 1/4" for towing purposes
true, but it a lot of it depends on the design. would you rather tow from a straight 1/4" tube, or a well thought out, well gussetted 1/8" tube bumper...
Lick my balls
I'm using a straight 1/4" tube right now, and the answer is yes, 1/8" no matter how well it is designed, is still only 1/8". I can assure you, you will never find a trailer hitch made from 1/8" for a truck.
If you were in the drivers seat of this truck, which would you want, a hitch made from 1/4" or a well thought out 1/8" hitch or bumper?
don't get me wrong waltman, I too would go at least 3/16 for any sort of frame mounting or somewhere its going to have pulling pressure, but in his case, I still beleive it would be alright if he took is 2x2 and made a bumper out of, like in the design of 90Beaters rock sliders. Then, obviously he'll need a hitch receiver and flat stock, so at least 3/16 on those. The rear frame mounts are only 1/8", so I really dont see a need for 1/4", only for rigidity, not getting ripped out.
Tubing
I have made about 10 Bronco Bumpers out of
1/8" Steel for the rae of Broncos and they have held up to some hard hits and offroading. The mounting plates I used were 1/4" with gussits.
1 - 13 of 13 Posts
