Well they don't call it "Soft Country"
At least it is truth in advertising.
Does anyone know what spring rate they use on there coils?
I can't recall I do have it favorited on this computer (my work computer) or my home desktop or my laptop. I'll have to see if I can find it.
IIRC stock front springs are like 340 +/- 20 or so. Rear springs however are like 370. If I'm not mistaken, most companies (skyjacker, superlift (excluding EZ ride) are 410 and rough country is 440-450 I'm pretty sure
***EDIT
Here I found these this info in my favorites-- This is lift springs for fullsize ford bronco (believe for 79's, but would be close to the 80-96 style)
Brand-------Bracket Material thickness---Coil Spring Rate
Trailmaster--4"-----None Given----------560 lbs per inch
Rancho-----1"------N/A-----------------459 lbs per inch
Rancho-----1"-2"---N/A-----------------380 lbs per inch
Rancho-----3"-----.19"---------------- 460 lbs per incharch
Rancho-----4"-----.19"-----------------460 lbs per inch
Pro Comp---4"-----.25"-----------------475 lbs per inch
Pro Comp---6"-----.25"-----------------450 lbs per inch
Superlift----1"-2"---N/A-----------------400 lbs per inch
Superlift----4"-----.25"-----------------445 lbs per inch
Superlift----6"-----.25"-----------------445 lbs per inch
ALSO -- Came across this info---
Bronco Graveyard: 3.5” Lift Coil Linear Rate(Superflex Coils from Deaver)
Part # 13206 190 lb/in <--- these are old style, new style is 300/inch
James Duff 3.5” Lift Coils Progressive Rate
Part # 5107 225- 445 lb/in
Rancho 3” Lift Coils Linear Rate
Part # 6403 485 lb/in
Superlift 3”-3.5” Lift Coils Linear Rate
Part # 13202 415 lb/in
And then the stock OEM specs for fullsize fords (the C# on left is moog stock part #)----
Also noted in RED is the actual spring rate so there is no confusion
You will notice 2 #'s per applications (4 for the f150, due to 1 is the supercab model) It's front, rear, front rear etc
CC818 12.13 1258 337 15.75 F150
CC820 12.13 1428 366 16.19 F150
CC822 13.00 1430 366 16.38 F150
CC824 13.00 1442 366 16.94 F150
CC820 12.13 1428 366 16.19 F250
CC822 13.00 1430 366 16.38 F250
CC824 13.00 1442 366 16.94 F250
CC844 12.75 1557 630 15.40 F250
CC844S 13.00 1759 629 15.79 F250
CC844 12.75 1557 630 15.40 F350
CC844S 13.00 1759 629 15.79 F350
CC818 12.13 1258 337 15.79 BRONCO
CC820 12.13 1428 366 16.19 BRONCO
