1 - 2 of 2 Posts
OK I search and I find measure this way measure that way measure this and that but I find a good solid front drive shaft on JBG and just wanted some form of reassurance this Driveshaft should fit.
Bone @$$ stock bronco 82 http://broncograveyard.com/bronco/i-32400_1980-87_front_driveshaft.htm
It seems this driveshaft should work up to a 6 inch lift? obviouslyi stretching it a little with a 6 inch or long travel suspension but I wont' be doing either of those for a minute as I plan on doing a SAS and Lift at the same time with the STRONGER LEAF SPRING!! Swap :chili: :popc1:
Measure the Distance from the bottom of the front yoke to the bottom of the Transfer Case Yoke and that is the length driveshaft you need.
1 - 2 of 2 Posts
