No not those kind...what do people use to replace a u-joint on the trail or do you carry spares with the joints already pressed in...I was thinking about this as I replaced my u-joints last week on my front axle. I wouldn't think a c-clamp would work...I bent a decent clamp trying to press out the old u-joint. Then moved on to my vise with a cheater bar and I still used lots of pressure and a good whack with a hammer to make it pop loose...I thought maybe you could use a high lift jack and rig it up to press against the bottom of the bumper with the u-joint in between...but what have others used?
